Technical 850 Parking brake / Handbrake adjustment?
Tiller
How is it to adjust the handbrake on a 1970 850?
After replacing brake pumps and brake shoes i need to adjust it
Other Forum Members can give specific advice, however if your model has the friction pad type adjusters on the brake shoes, then with handbrake cable backed right off, I always adjusted the shoes using a screwdriver to prise them out slightly on their pedestal/pins so that I could just slide the brake drums on, to the point where the drum would just bind a little, then give the drum a tap with a copper mallet to centralise the shoes, the drum would just spin freely then but still in close contact, after that I would readjust the handbrake and work it and the footbrake several times to ensure not binding, followed by a roadtest and recheck for binding or even if any hint one wheel/drum was warmer.
This has stood me in good stead since 1969 on many Fiats and also whilst working as a foreman at a Lada Dealership where Lada models (Fiat 124 under License) used the same system.
Other things I have noticed relating to this system is if cheap brake shoes are used then the brake shoe return springs will overcome the friction pads and so give a poor brake pedal and cause issues adjusting the hand brake:)
