Technical 75 ELX Battery
arf85
The battery on my 75 ELX mk1 punto went flat and i am just wondering what would be the best way of re-charging it? do i have to disconnect the whole thing or noT? i have a car battery charger but am unsure what to do.
Please help
well at the front of the battery towards headlight, undo the bolt at the base to get the battery out, undo the bolts on the clamps on the terminals, pull them off, i normally pull neg off first and put on last, not sure if thats the proper way tho! lol
and then put the red clamp from the charger on + and black on - and turn it on :) and if its got settings, make sure there all correct.
why did it go flat? if it went flat all on its own then it probably needs replacing,
any way to charge it i would remove it from the car remove the lids and be carefull as when its charging it gives off inflamable gas, follow instructions that came with the charger
:nono: why did you reply to this one, now theres 2 threads, when you could of deleted this one :p
edit- now you've sorted, trying to hide your stupid mistake :p
