I am in the process of re-building my 650cc engine. The old timing chain was quite slack and has no tensioners. It was pointed out by Toshi that it is probably off a 126 Bis. So I bought a new one with sprockets and tried to fit it last night. However there does not seem to be enough slack in the chain to get it on. I have tried envy thing I can think of but once the chain is on both sprockets I can quite get the camshaft sprocket onto the end of the camshaft. It needs a few mm of slack. Any suggestions? The old one goes back on fine and the slack that was there before striping appears to have gone, so I could always use that I suppose.
In addition, since replacing the main bearings and re-fitting the crankshaft, there is a few mm of play (i.e. horizontal movement in the crankshaft). I can't remember if that was there before I striped it down. Is that normal?
Jamie
Jamie
