6 speakers / 4 outputs?
chrisfunk
Darlington, Co Durham
Hi all
This is probably a daft question but i just wanted to make sure before wasting any money.
Are the 6 speakers in the marea fed from 6 outputs on the original HU, or are the front tweaters set up 'in line' with the door speakers?
In other words, If I put in an aftermarket HU with a standard 4 outputs, will all 6 speakers in my Marea still work?
any help appreciated.
cheers
StiloJoe
Notts
If this is same as most 6 speaker systems The front tweeters join withthe front mids (door speakers) and from there feed to the back of the HU
So yes all will work fine as normal just putting a bit more power in than the standard HU
Dont worry about daft question We all have to learn somwhow (y)
OP
OP
C
chrisfunk
thanks for the reply and nice motor!
do you know much about car audio?
I'm doing my own nut in thinking about all the options
for my marea.
Bought it with just the tape radio / 6 speaker system.
I want a cd player, but it must work with the steering controls,
and i want to add a small active sub later on (Fli 10" or similar).
We've established that the 6 speakers should be fine with any cd player so that opens up the options, but I am having trouble finding cd players that are compatible with the steering controls, at least units for less than £250.
The main reason for a new HU at all would be for the sub output, but i understand you can use a 'high level' input. So could you infact connect a sub to the original HU if i found a marea cd player (which would keep i looking standard which i will do if possible)
so many questions! what have you got in your stilo?
StiloJoe
Notts
for my marea.
Im pretty much clued up on audio
This is my HU
Im well happy with it for MP3's and such
Your best bet if you want to run a sub is using RCA's and ot bother with high level inputs
Just a quick search came up with this
Eg Sony HU connector
http://caraudiosecurity.com/shop/product/products_id/2077.html
You then can plug that into your existing wiring with your new headunit and still use the controls
When i had my punto MK1 i hand controls too and a sony HU and got them working just fine with hardly no hassle at all
Hope that helps
OP
OP
C
chrisfunk
thanks for that, think i'm heading in the right direction now.
shame these websites dont make it clear which units are compatible with the connectors, having to look at each units specs is taking ages, but i'll get there.
thanks
StiloJoe
Notts
No problem but if in dought just check the HU manufactors site for more info if not contact them and ask
Most Sony, Kenwood, Alpine and such are conpatorable Jut need the right connector which most of the time you can get from Autoleads
Any more questions feel free to shout
