Thank you all for your replies. To answer some of the questions that have been raised: On the fiat 500 I have the rear cylinders are held by 2 bolts through the back plate. One is easy to access with a 10mm spanner, the other is fit snug against the trailing arm. There is no clearance similar to as shown in one of the articles on this forum. You can get an open ended spanner on it but both brake pipe and bleed valve further restrict any movement. the spanner slips on the bolt. So I am needing to get better access meaning I need to remove the drum, hub and move the backplate to gain better access to the cylinder bolt. Unfortunatly the bolt needs removing and replacing along with the cylinder. Shouldn't be too difficult!
Anyway thanks again for the responses. One further thing - someone said "download the manual" - that seems reasonable - but to download do I really want to give my facebook account, address book etc to someone I don't know - I think not! Again - could I be sure it contains the info I was after - maybe, maybe not - if the guy knew it did why not just post what it was?
