the 55 and 60 TB's end up the same i believe, and tricker bored them both out to the same 40mm
punto_lad said:is there any difference boring out a 55 tb to 40mm than boring out a 60 1242 one to the same? can the 55 be bored out the same to 40mm?
uno_94 said:can any one tell me do you tell insurance? what do you tell them? can they check?
and what do they sound like on idle? and upto 3k revs?
punto_jr_sx75 said:i wouldnt declare one to my insurance
chaos said:FFS Beau, you ask this every time a mod is mentioned What were you told before?
Then you would be stupid
Any mod must be declared to the insurance co - if they find out a mod has been made and not declared, they would have every right to invalidate your policy - which could land you in all sorts of bother
punto_jr_sx75 said:I can fully understand that, but it would also invalidate it if it had one on when i bought my car and i didnt know about it. The only reason i wouldnt declare it is because being 17 and just passed my test, any mod like that would raise my insurance to over £3000 per annum. Again, i know you'll say 'well you shouldnt put one on', but then again, its not very likely that a crash report engineer would be able to tell. I can fully see you're point, and i know that if i could afford one AND insure it then i would have it, but at the min my car is insured as TPFT and thats ridiculously priced as it is.
Jordan
J333EVO said:It makes no differance whatsoever which TB is used as they are drilled out and sleaved to make the 40mm TB. So if you have both send the smaller 55 30mmTB away to be made into a 40mm one and sell the 32mm to someone who can't afford/isn't prepared to buy the 40mm one.
Aaron.
