- Joined
- Feb 16, 2005
- Messages
- 5,983
- Points
- 988
I plan on injecting very close to the valve just like it is on a single throttle body multipoint setup.
As I have fully sequential and a close injector, I can time the injection to occur just as the inlet valve opens or just before (or wherver it responds best. I can ajust the injection timing based on rpm and load as well
. The injectors I use have good atomisation.
Above is a Bosch EV12 type off a punto abart turbo (already running these).
I wan't to retain the TPS purely for TPS Accel Enrichment. I will run hybrid, or pure apeed density.
I won't be linking all 4 vaccum lines up together. I will be building a synchro map as per here:
http://www.msefi.com/viewtopic.php?f=38&t=33901
There are some new developments being backported to MS2 from MS3 that will greatly help with MAP signals on ITB's as well
Cheers,
kristian
Cheers,
kristian
