Hi all, I am aware of the pre 2015 model brake noise, when in reverse, and the damper kit that solves the problem.
Vehicle has 31k kms on now, pads still look ok, and the Dampers are fitted as it is a later model.
I cleaned the Calipers, and used Liquiy Moly anti-squeal and it was fine for a day, and then back to sounding like a whale when I reverse.
The discs don't look great either, seemingly scored slightly. Any advice before i replace pads and discs for good measure?
Your advice and thoughts will be sincerely appreciated
