Hi guys
I have a 2017 Ducato Multijet 2.3 - 180 with Comfort Matic gearbox.
I am told that the hydraulic fluid for the clutch should be changed every 2 or 3 years. I have done it in other vehicles with a clutch pedal, but I don't know how to bleed the system to replace the fluid with the Comfort Matic. Is there a way to operate the actuator to pump the master cylinder and keep it pressed while releasing the pressure at the concentric slave cylinder nipple (like in standard manual clutches) ?
Thank you.
Thank you.
