4x4panda2016
- Joined
- Oct 22, 2021
- Messages
- 7
- Points
- 2
Hello, I have lurked on the forum for ages but now have a question to ask. (Thank you for the posts about the rear discs, could not believe how complicated it all is in the newer design!)
I'm trying to change the center support bearing on the main drive shaft to the rear (NOT CV), I am aware the UJ is staked and will need to go to a specialist to be replaced and that it can be a hassle to separate the shaft next to the yoke.
The problem is with all bolts out at both ends and center bearing, the shaft can flex but it won't come out, it seems like both ends are stuck. Every source I have found the shaft is already removed or just lifts away so I don't know why its stuck. Is there a circlip or something inside the housings on each end, or are the end bearings just seized? cant even tell if the shaft should remove from the end bearings or if they should stay with the shaft.
Its a 2016 so have Fiat changed the design? Is it still possible to separate a splined section next to the yoke or does it need cut and re-welded to get access to the bearing? Either way surely the shaft must remove from the car, can anyone help?
