Technical 2015 fiat ducato - no fuel rail pressure
2015ducato
NN10 0SB
Hi ,im Steve with a no start Ducato. Bought with a knocking engine and its done 213,000 miles. It was going to be my pride and joy after restoration , but has left myself and others with a heavy heart. I rebuilt it with a new crank, rebalanced rod, turbo cartridge, oil and water pumps and so on. It ran for a few miles until the ecu light came on. It had started to produce white smoke - lots of it- and pressurise the fuel return pipe before failing to start. Fitted a recon Bosch pump, pump solenoid and rail pressure sensor. There was possibly some corrosion in the ecu ,so an exchange unit was fitted and a new relay control box. The key and immobiliser seem ok and a new starter was fitted during the saga due to slowing up. My question is have we missed something ?, there is only 6 bar of rail pressure , what other influence controls the pump.( the priming pump is bringing fuel to the high pressure pump). Used injectors were tried .compression is between 360 and 380 psi. Its had 3 different code readers on it and apart from no rail pressure, we have an open circuit on the glow plugs which were renewed. Any ideas ??,regards.
Hi Steve
I can imagine you are tearing your hair out after that saga ! You seem to have checked out most things.
I can only offer "unofficial" advice pieced together from various sources. It's given in good faith but no guarantees ! My data is for the X250 model. I'm assuming yours is an X290 with a 2.3 Litre Euro 5b engine, which is likely to be similar but be aware that it may have some differences
Sounds like you have things mechanically OK and have good compression.
Slow cranking can be Low battery, Faulty Starter, Bad connection in the +ve feed cable or Bad connection in the Earth return. The last includes the notorious corroded engine to body earth strap, which can affect anything that earths to the engine rather than the body. This includes Starter, Alternator and Glow Plugs. Unless it has recently been changed, I recommend fitting a new one. Don't just clean up the ends of the old one, the corrosion is hidden inside the crimps.
The low pressure pump is capped at about 6 Bar. Once the engine is turning, the mechanical HP pump raises this to as much as 1600 Bar rail pressure. Normally it doesn't have to build up from 6 Bar as there is a non-return valve, but it can if necessary. Unless you get to at least 200 to 300 Bar the ECU will prevent the engine starting. If you are cranking OK but only seeing a very low pressure it suggests a sizeable leak in the high pressure system. I can think of 4 possibilities:
External leak - this would be obvious, so it's not that
Internally Leaking Injectors, but you have tried others and the ECU probably doesn't trigger them anyway if rail pressure is too low.
Internally leaking High Pressure Regulator Valve (Part of the HP pump), unlikely as this was renewed along with the new pump, but cannot be discounted.
No electrical drive to High Pressure Regulator Valve, so permanently open
The regulator valve N193 is driven by the ECU M010 by a pulse width modulated signal at about 1 kHz, so it can be smoothly controlled over a range of positions to control the pressure. There are 2 wires:
Power from ECU Connector A, Pin 19
Control from ECU Connector A, Pin 49
I think the next step would be to use an oscilloscope to check that N193 is getting the correct drive and is drawing the right current. You could also possibly divert its fuel return pipe and visually check that you don't have fuel returning during cranking, when it should be closed or almost closed.
For completeness I should mention that the ECU drives current to the Regulator Valve, The Injectors and a number of other actuators. This all takes power, so if there is any shortcoming in the power going TO the ECU it can affect its ability to deliver. Check out the various fuses supplying the ECU, they are listed on Elearn which I'm sure you have a copy of.
I wouldn't worry about glow plugs at this stage, as they are mainly needed for starting below about 5 degrees. They should measure about 1 ohm each when cold. Their current is monitored by the "Relay" and if not high enough it will throw an error. However, this could be the earth strap or a poor connection to the glow plug, and not necessarily a failed plug.
White smoke is unburnt Diesel, which is mostly seen just after a cold start (especially if glow plug(s) aren't working). If you see it any other time, it's a sign of massive over-fuelling.
Good Luck !
Hi Anthony, thanks for your extensive analysis ,i think it gradually lost fuel pressure which i believe is also a cause of white smoke and excess injector return flow. I have left it to my friend, who is adamant, he will find the fault once he returns from holiday. I will give him your report and will update you when finally running, thank you, Steve.
