Help please. Comfortmatic not finding gear. Well I have read most of posts on this and thought I had a winner. With just ignition on I could select N auto Reverse , first gear . manual . So dived in to look at Dot 4 container . Yes it was empty. I topped this up and bled the system with aid of vacuum pump on the nipple . So what has this done for me, well nothing . Now it will not select anything with just ignition on or engine running . Just coming gear unavailable. only thing it will do is change from N to auto N . Any ideas . Where is the pump relay as I cannot hear that running now but could before . My Icarsoft scanner is not finding any fault codes . I have checked the fuses in the little strip behind the main fuse box as believe these are the fuses for the comfortmatic
