jamescr
Hi all,
I'm hoping someone here can help me diagnose a strange issue I've been experiencing with my 2011 Fiat Punto Evo 1.4 FIRE.
I only purchased it around 5 months ago so don't know too much of its history (no service history) but soon after noticed that sometimes on idle or at low revs (mainly around 1500RPM), the vehicle would judder(/kangaroo?). It seems to happen more often when the engine is warm. One day it was particularly bad and I had the engine warning light come on but after turning the vehicle off and letting it sit, the warning light disappeared and has not returned so far (touch wood!)
To date, I've replaced the coil pack and spark plugs and also used 2 bottles of injector cleaner (the type that goes in the fuel tank). Whilst these seem to have reduced the issue, it is still occurring. I've now used an OBDII reader on the vehicle to try and diagnose as I thought this would confirm a misfire on one of the injectors but it showed no codes stored. I have also had the cam belt changed recently as a precaution.
My only remaining thought is that the injectors are still dirty or partially blocked and therefore may need manually cleaning although if this was the case I expected this to be picked up on the OBDII reading? Therefore, I just wanted to ask and see if this seemed reasonable or if I'm missing something completely here?
Thanks in advance for any help and guidance!
- Model
- Punto Evo 1.4 FIRE
- Year
- 2011
