Markah2007
- Joined
- Feb 4, 2018
- Messages
- 18
- Points
- 9
Hi guys, recently bought my daughter a fiat 500, when test driving it, it had a very low bite point and the clutch was sitting half way in and not returning to the correct position and was a bit stiff to press in.
I knocked the seller down £300ish and the weekend fitted a new clutch kit and slave cylinder.
bled the slave and took it for a drive yesterday, the pedal is now soft to push in but still isn't springing back into place properly, its returning slower than it should and doesn't feel right, still seems a little spongy.
I thought maybe it needs more bleeding but after attempting to bleed the slave more the pedal is just sitting on the floor, will stay at the top if i lift it manually but theres no pressure at all no matter how much i pump the pedal by hand nothing happens and the fluid reservoir doesn't drop, i also noticed the black rubber seal and metal rod are wet on the master cylinder behind pedal.
Im trying to find a master cylinder but eurocarparts and carparts4less dont sell one and searching online i cant find any product made by LUK or Valeo.
Only items i could find were made by abs or lpr which ive never heard of and imagine are poor quality.
Ive attached a picture of the type below as theres a few, of anyone could help me find the part I'd really appreciate it.
Thank you in advance, mark
