Technical 2009 grande punto fuel cut off
Mickeyr72
Peterborough
Hi all, as the suggests got a grande punto 1.4 petrol 2009.
Fuel cut off unavailable message on dash ?
At 1st no cranking either but after a lead clean up and fuse check it's cranking over but same fault displayed on dash ?
Tried the obvious
Searched for reset switch (both door pillars)
Should mention its UK spec right hand drive.
No sign of a reset button anywhere for the fuel pump ????
Can anyone confirm where it should be ?
Has all trims off and no sign of it ?
Google says on door pillar behind trim but not there ??
I would appreciate some advice :)
OP
OP
M
Mickeyr72
Peterborough
Tried the obvious
Hi got the Amber light on with pic of car and padlock ?
Does this suggest immobiliser has forced fuel cut off 🤔
OP
OP
M
Mickeyr72
Peterborough
