Technical 2008 scudo repair manual
Mikeblidari
Hi all, thanks for having me.
My 2008 scudo started for 6 seconds one morning and now it's a non runner, some fault codes indicate short to ground and/or no communication with the instrument cluster, and also unknown faul code P1210 which my delphi does not recognise.
I am suspecting electrical fault and would be very helpful a rapair manual.
Does anyone have an electronic version or a link where to get it?
Thank you.
OP
OP
M
Mikeblidari
Hi, yes it used to say 8 bars on demand and 320 something requested by the system.
After measuring the sensors and wiring now it shows 0 on both?!?!
Near the M4
So thats a fuelling issue..
Either not holding pressure..
Not actually rrceiving anything from the tank..
OR a dodgy sensor feedback
I suspect its 'French'.. so cannot quote specifics..
but checking the fuel pump runs..and it will refill the filter you check for water
Will certainly be a good start :)
OP
OP
M
Mikeblidari
Did fuel test, the prime pump it's getting harder when primed but stays when cranking the engine...usually they go soft as it releases the fuel, fuel comes to the injectors do not know if the right amount...today if I have time I will do a fuel pressure test if I find my testing kit.
OP
OP
M
Mikeblidari
S-o I tool the fuel pump apart, everythong looks ok, took off the fuel pipe that's going to the common rail and nothing is coming out.
Any of you could check k with a voltmeter on second senzor below the pumo what voltage is coming out when cranking the engine? I have between 3 and 6 volts for a second then 0.
Thanks.
