- Joined
- Jul 4, 2011
- Messages
- 32
- Points
- 13
Hi all I have the Above car and problem.
At first it was the intercooler pipe had a hole in it and then the turbo stoped working.
Then we checked the map sensor which was all clogged up so it was cleaned and then it was over boosting because the sensor was broken so got a new one and the turbo doesn't boost.
Then tried a new maf sensor but the same problem.
I had a new fuse box fitted because some fuses and parts was corroded but the turbo is still not working.
The failure code is saying it a pressure problem but we have tried all.
The turbo will kick In On idle
Anyone have any ideas the next thing we are looking at is the engine ecu but I don't want to buy one if it's not the problem (400-600 from fiat)
Any help would be great. Cheers
