Technical 2006 Fiat Stilo 1.9JTD over reving
Sarel
Hi
Sarel here from Delmas South Africa
I just want to find a solution for the following issue
I bought a 2006 Fiat Stilo 1.9 JTD. The problem that i have the car tested and drive 100%. Yesterday i decided to wash the engine, (fuse fox and connectors and ecu was covered with a plastic bags). After i washed the engine i started it up and it started just fine and idle for 5 minutes then it just rev up and reached the limittor, i switch it off and start it up again, same story, i connected my Delphi diagnostics and found no errors, i disconnect the battery overnight and tried again this morning, same result. I went through every connector, fuse boxes ect....cleaned the egr valve but still the problem remains, what can cause this wierd response?
