Technical 2006 fiat panda (188) starter motor relay switch.
Lemonlion
South Africa
Location of this please, (preferably with picture please?) Need to test if is the relay or starter. Have a new battery in but when trying to start it sounds grrrrrrrrr or trrrrrrrr.
bugsymike
Well-known member
Torbay
If the noise is coming from the starter then the relay has sent power to trigger it.
Assuming the engine isn't seized i.e. with ignition off it is possible to physically turn the engine by hand or a spanner.
If that is the case then I would check main heavy battery leads to the starter and also the battery earthing points, making sure they are clean and giving a good electrical connection.
Generally if someone tries to start it a few times and then you put your hand on the leads, connections and the starter it's self, the offending article will be warm to the touch, due to the heat caused by the high electrical resistance.
Always assuming your new battery is in good fully charged condition.:)
OP
OP
Lemonlion
Lemonlion
South Africa
It starts when given a slight push, think that helps the starter to kick. Will take it off and take it for service. Prop just needs other brushes.
koalar
Well-known member
Cheshire
2006 fiat panda (188) starter motor relay switch.​
There isn’t one ?
As per fiats description
“starter motor consists of a direct current motor supplied by the battery and an excitation solenoid.”
The solenoid is bolted to the side of the stater and is supplied with 12V. If memory serves me right a thin brown cable.
Is it a turn noise or a quick clicking noise you can hear ?
OP
OP
Lemonlion
Lemonlion
South Africa
There isn’t one ?
It is a quick clicking sound
koalar
Well-known member
Cheshire
Not enough current getting to the starter
The solenoid is bouncing on and off
battery is the most likely
Faulty cables, dirty terminals or earths
Does it work okay with a jump start
OP
OP
Lemonlion
Lemonlion
South Africa
Yes drives smooth. No probs.
koalar
Well-known member
Cheshire
So it starts with these ?
Battery most likely
Lead to starter motor
Earth under the clutch slave cylinder
Dirty terminal leads
OP
OP
Lemonlion
Lemonlion
South Africa
Thanks guys. I will take car to an auto electrian on monday to have it inspected. Will post findings
Hi You guys, sorry it took solong to come back. Was down and out. Had the car by auto electrician and it was indeed the ground wire to engine block like you guys suggested. Took another wire and looped it to another spot on engine. Now starts like new. Thanks a mil all.
