Technical 2006 1.2 dynamic rear door
18turbo
When I put panda into reverse with the wipers switched on the rear door unlocks, but it is ONLY when in reverse with wipers ON, any ideas how to fix ?
Where the wiring passes from car to door, inside the rubber bellows, you will probably find some have chafed and touch, so the wiper signal goes to the doorlock.
Or more likely, the earth connection needs cleaning. If wiper circuit cannot earth properly, it may be finding an earth through the doorlock. I think the earth point is left side of the boot behind the trim.
If you check the connector for the passenger side rear light cluster, you will probably find that it needs a good rub down and clean. Damn thing had mine going nuts till I got it cleaned.
