CeriR
Our 2001, 1.9td, 5 speed Ducatto gearbox in our Moho has started crunching when selecting 1st if moving slightly and 4th while driving along. 2nd, 3rd and 5th are currently fine. I've recently bought the Moho with a lot of travel on the clutch pedal so had a new clutch fitted and they changed the gb oil and found some water in it. I've now read threads that say this is a common problem and I'll look at finding the solutions to the water ingress. I'm currently in France and driving around the selection problem by shifting from 3rd to 5th whenever possible and not engaging 1st unless stopped. I'm guessing syncomesh problems? and gearbox work/recon swop when I get back? Can I ask is it true that the gearbox oil quantity was upped by Fiat from 2.5 litres to 3 litres? If I check with the garage that fitted the clutch if they added 2.5litres will an additional half a litre help my situation or not?
