I may have to remove my 2.8 JTD engine from my 2003 motorhome. The engine lost coolant on the motorway and after changing the hose there are
a)exhaust fumes in the water,
b)low compression on at least one cylinder
c)the starter"spins up" on starting and
d)once the engine warms up there's a slowing down of engine response.
The garage who did the check suggests it needs a replacement engine / major rebuild. At the minimum, the Head gasket needs replacing, and a soft seize is suspected.
So the engine probably has to come out.
Is there a guide to doing this on this site, or a manual that can help?
The garage doesn't want to do the job as they are so busy at the moment.
