biggelmo
Hi, I'm in the process of installing a chinese diesel heater in my 2008 Scudo 2.0Hdi.
Rather than using a separate tank to store and supply fuel to the heater I would like to use the van diesel tank for this.
To make thing potentially simpler than having to drop the van fuel tank I am thinking of linking in to the main supply fuel pipe from the tank to the engine if the pressure in the pipe is low enough.
So what I really need to know is......
1.Does a 2008 2.0hdi have a lift pump in the tank ?.
2.Is the lift pump built in to the high pressure pump on the engine ?.
If there is no lift pump in the the tank then I may be able to link into the main fuel pipe and take a feed with a one way valve to supply the pump for the heater.
Any ideas ??
Any ideas ??
