A alex403 New member Joined Jul 9, 2006 Messages 84 Points 22 Location Norfolk Jul 9, 2006 #1 hi ... i was wondering what size offset i will need for my alloy wheels to avoid using wobbly bolts? I am going to fit 16" Cheers
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,609 Points 10,657 Location Edinburgh Jul 9, 2006 #2 offset has no bearing on using wobbly bolts.thats PCD
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Jul 9, 2006 #3 welcome to the forum pcd=4x98mm offset(et)= 38mm center bore = 58.1mm
OP OP A alex403 New member Joined Jul 9, 2006 Messages 84 Points 22 Location Norfolk Jul 10, 2006 #4 cheers for that guys ... i have found these wheels, do you think they will fit without any trouble or needing wobbly bolts? http://cgi.ebay.co.uk/ws/eBayISAPI....70005997477&rd=1&sspagename=STRK:MEWA:IT&rd=1 cheers Last edited: Jul 10, 2006 This post contains affiliate links which may earn a commission at no additional cost to you.
Patch124 New member Joined May 25, 2006 Messages 75 Points 33 Location Leeds Jul 10, 2006 #5 alex403 said: cheers for that guys ... i have found these wheels, do you think they will fit without any trouble or needing wobbly bolts? http://cgi.ebay.co.uk/ws/eBayISAPI....70005997477&rd=1&sspagename=STRK:MEWA:IT&rd=1 cheers Click to expand... They will fit but ure gonna need some slim tyres on them to prevent rubbing on the sills.... look good tho This post contains affiliate links which may earn a commission at no additional cost to you.
OP OP A alex403 New member Joined Jul 9, 2006 Messages 84 Points 22 Location Norfolk Jul 10, 2006 #6 they come with tyres as standard so i will probs use them ... if they rub cant i grind a bit away from where they are rubbing? cheers
