Steve Unreal
I have a 1999 MK1 Fiat Punto 1.2 Litre, Currently has standard wheels, will 17" Alloys fit and work ok on it?
Well considering Im new, im not sure which area to put it under and I need a fairly quick responce then yes I do feel I needed 3 threads. Is that really such a life destroying issue?
you need to learn how to use a forum.
if you dont follow the rles people will not help generally.
I think you might get away with 17's but it will look crap and ruin your gearbox and other components.
so do the rest, supposed to use report button not flame the new guy
crap cleaned.
Hi there mate welcome to FFI have a 1999 MK1 Fiat Punto 1.2 Litre, Currently has standard wheels, will 17" Alloys fit and work ok on it?
I very much doubt 17's would go on without rolling the arches and such like, Its hard enough with the MK2.
17's go on a MK2 fine so i dont know who told you that.
Down to width offset being wrong doesnt mean they will do it on every car. Just have to make sure you get the right offset for the car and space the wheels out if they do rub. Its nothing major.
Spigots have nothing to do with the offset of the wheels they are just changed to cater for change in hub size between different cars. Again if the wheels are the right offset lowering wont cause any problems. I know a lad with a mk2 running 17s and he is lowered over 100mm and doesnt rub in the arches.
No he just got the right offset so they sit in the arches perfectly. Fronts rub when on lock but thats sort of unavoidable when you are that low.
