Mark Saunders
Can anyone confirm the order of the pins in the injector loom socket relative to the cylinders, and what correct resistance should be? Vehicle is a 2000W 16V and injector is 71737174 according to Eper, which I believe is IWP109 type.
My symptoms are cylinder 4 dead (no change when I pull the plug lead) and cylinder 2 week relative to 1 and 3 (pulling the plug makes less difference than with the others). Ignition light is on. Car seems te be capable of using about £5 of petrol in a five mile journey (to be fair, last time I was revving it to the limiter to see if it cleared anything).
The fault developed at the same time as the battery died and, strangely, replacing the battery cleared it for a few days.
Readings on the pins from top to bottom are:
Nothing
25 ohms
8 ohms
25 ohms
Bottom pin appears to be the common.
Both sets of symptons suggest the pins, reading top to bottom connect to 4, 3, 2 and 1 cylinders and I have one failed and one failing injector.
I haven't had the code read and have been playing around with Bluetooth ELM27 devices that don't seem to work with my ECU (Marelli IAW 49F.B2/HW002/4974-MEM).
It looks like a fairly straightforward job to replace the injectors - is there anything I need to know before embarking on it?
Nothing
25 ohms
8 ohms
25 ohms
