Bought some 15s off ebay a couple of days ago which said it will fit my cinquecento sporting but my friend tried to put them on but said there is no point cause its to close to the springs, anyone else had that problem and solved it?
cause that will be able to tell us the offset, and from that we can find out wat size spacers u need to get them away from the springs and fitting properly
I notice that the seller has omitted the offset on his advert, and even suggests that they will fit punto and cento, even though the offsets are different.
Do the boxes have an ET number on them. or even the wheels themselves?
lookin at those wheels mate, u need to find out the PCD as well, as they may will be 4x100 instead of 4x98 which the cento is....
as david said, there should be a stamp on the inside of the wheels which will have ET and a number, and maybe even the stud pattern... once u have those 2 numbers u will be able to tell wat size spacers you need, and you may even need wobbly bolts.
