MArkJohnAsh
Hi All.
New member here.
I have had a 8v 1242cc Manual Panda for a while now and love it for what it is but have had an ongoing problem with it for 2 years +
Im mechanically competent doing all my own spannering on my own cars but Im not super electronics literate. There have been lots (49) of Alfa's, a 74 Spider, a 147 GTA , an 1971 850 Coupe, 16v integrale, Uno and currently and 2015 Lotus Evora. My bright yellow Panda is still a favorite.
I have silly competitions with myself about how little I can get it to use and have got it with a lot of effort to 58 MPG average for my old weekly work commute
My issue with the Panda is that (ONLY IN FIRST GEAR, COLD or WARMED ENGINE) it wont let the engine rev past around 3000 RPM 50% + of the time. Its not a "soft" stop, its like you turn the ignition off. Calling it a flat spot is being generous, more like a pit of despair. Its so bad and unpredictable that I have changed my driving style so I always change to 2nd before getting to 3000 RPM in 1st. Doesn't matter if you hit this rpm at full or light throttle, it just stops and you end up bunny hopping and having cars behind you almost hitting you
I am thinking that this possibly may be a emissions thing FIAT has mapped into the ecu but it would be pretty brutal if that's the case
If it was something like a AFM or electrical (excluding ecu mapping) it would happen across all gears. I also though the ECU may not let you rev the car in First gear when engine is cold but the problem happens across the engine temp range (and goes on to let it rev in higher gears)
As a fault diagnosis measure I have thought about disconnecting the sensor that the ECU measures speed from to see if this tricks the ECU into doing something different but dont know what the ECU measures speed from (ABS wheel sensors maybe? or speedo?, unsure)
Other than this it runs fine and has continued to for 20,000 miles giving great gas mileage.
Any ideas from anyone?
Mark
New member here.
Mark
