Could you put this in an 1108 engine - instead of performing full engine swap?
Or am I missing something really obvious?
*hhhmmm*
Cheers,
Matt
*hhhmmm*
Cheers,
Matt
The block is the bit that bolts onto the gearbox, and the head bolts onto the block. It's possible, I suppose - but it's easier to take the whole engine and 'box out and change things over before bunging it back in.bad_boy_racer said:Could you put this in an 1108 engine - instead of performing full engine swap?
*hhhmmm*
Cheers,
Matt
fixitagaintomorrow said:As long as you find some way of dropping the compression ratio, either with machined pistons, shorter rods or head gasket spacer (although I understand these are unreliable).
If you don't drop the CR it'll pink like mad and burst.
