I have read and re read most if the posts on this subject, but can't establish whether the beam axle is common across all 2007 model year Pandas or not - no doubt someone will be able to point me to a relevant post, if not please help me on this matter. :worship:
We have a 2007 100HP model, white with double sunroof, which we have owned some 12 of its 13 years - very happy once we sorted ride with proper dampers. I repainted the rear axle a few years back, but despite this it is deteriorating. I was in the process of removing rust when I broke through the vertical section close to the damper mounting and thought, this requires more than paint!
I could probably get it weld repaired, but would like to replace, if at all possible, as rest of car is pristine (only 55K miles too). Various parts suppliers (I haven't tackled Fiat yet) seem to differ, some list 100HP axle (but out of stock) others list one axle, seemingly for all Pandas of this age.
Only difference I can see in vehicle spec (apart from impact of track through wheel sizes) is the addition of disk brakes on 100HP and 4X4 models but callipers appear to be mounted on the hub carrier.... So should be no need for different part. Am I right or am I going to have to take the bitter pill and source from Fiat?
