Following problem on an MK2 1.4 i.e. engine:
The engine starts from cold, when takes of in first gear but as soon as it gets to constant speed or decelerates, the engine stops responding and shuts off. On occasion it will restart itself and continue accelerating when the gas pedal is pumped.
Also when revved at (rough) idle, the engine stalls when the rpms fall.
Fuel filter, spark plugs, ignition coil pack and cables, hall sensor, possibly ECU have been changed. Switched lambda for fuel pump relay, no change.
Any ideas other than wiring fault or injection unit?
