P94smv
Recently purchased half done project I’ve sorted besides wiring
Car came to me with 16v loom fitted and ecu mounted in oe cinq spot
I’ve since used all the guides I’ve found on here but still not heard fuel pump prime or seen spark
My issue seems to be with cinq d4 into punto d4
I’ve had ecu immob taken off using the cinq code box and key but still get code light
Can I just unplug the box under dash ??
I’ve got all gauges on dash working it seems
Punto black/red is live off battery
White relay is live and tps also livens off ignition
Earths are cinq loom to gearbox , battery to chassis , battery to block , big bunch on rear of engine
I’m noticing the ignition light seems to be lit even with keys out the car
Awaiting battery to recharge so can have another try
My cinq doesn’t seem to have a spare bullet under battery tray the 2 plugs I do have are plugged in which are 2 thick reds on 1 plug and red/back - black/purple
