RampantParanoia
Hi all,
My mate recently bought an 02 plate Seicento SX with 99k miles on it and the 1.1 MPI engine. The head gasket pretty much went immediately
I'm pretty handy and the engine doesn't look too complicated so I figured I'd help him do the head gasket rather than take it to a garage. When I took the head off most of the coolant ports were largely blocked with corrosion, so I can see why the gasket went! I got the head pressure tested and skimmed, and had some welding done as well as some coolant ports were eroded. I also replaced the water pump while I was in there as it didn't look great.
Once it was all back together I put some speedflush into the coolant system to get all the remaining corrosion out, then drained it and put antifreeze in etc. It seemed to be running fine although idling a little bit low, so I gave the car back to him. Within 20 miles he said that the EM light was flashing and it was intermittently losing power, so I did some googling and came across the phonic wheel learning procedure and had him do that. It didn't seem to work so I had him do it again, then it started blowing white smoke out of the exhaust.
I have no idea what's wrong but all signs lead to the head gasket again, but I can't see how it would have gone again so quickly?! Any ideas (constructive criticism on my workmanship is welcome!) ?
