'20 Panda Hybrid Sport
The showroom shot those wheels look Massive. I guess they are the Summer wheels.The size of the tires is 195/45 r16, I chose winter tires without hard sidewalls, so the ride is relatively comfortable, I have them worn on steelies which should be lighter than OEM alloy wheels.The local user The Pretender inspired me to choose a winter set of discs .
Hi @Sparkus2The size of the tires is 195/45 r16, I chose winter tires without hard sidewalls, so the ride is relatively comfortable, I have them worn on steelies which should be lighter than OEM alloy wheels.The local user The Pretender inspired me to choose a winter set of discs .
Zuberec when I'm there; I see you are in the East....Hellou Panda IIs.
Good point, a few days ago I saw a yellow Panda in front of the very small post office for very first time. Panda is not a common car in our country, mostly used only for food delivery Where do you live in SK ?
You right. In Zuberec is 4x4 necessary during winterZuberec when I'm there; I see you are in the East....
Look great steelies with wheel covers.The size of the tires is 195/45 r16, I chose winter tires without hard sidewalls, so the ride is relatively comfortable, I have them worn on steelies which should be lighter than OEM alloy wheels.The local user The Pretender inspired me to choose a winter set of discs .
No, not interchangeable, different shock/spring lengt, different spring rate, and some minor attachment points differences.Yes, you are right. That's why the 7x16 "et30 winter wheel set fits better there. I have a question if there is a proven set of shock absorbers and springs that works better on poorer surface quality. OEM settings don't suit me, the car is very restless. Suspension on Fiat 500 hybrid of my wife is much better on the same whell/tire size, are the f500 / panda chassis parts interchangeable? Thnx for your answer.
Question, how does it ride, the 70 hp 1.0 Hybrid. ??The size of the tires is 195/45 r16, I chose winter tires without hard sidewalls, so the ride is relatively comfortable, I have them worn on steelies which should be lighter than OEM alloy wheels.The local user The Pretender inspired me to choose a winter set of discs .
