Recently started having an issue with the lights in that the dipped beam comes on for a few seconds or flashes on and off repeatedly for a few seconds when indicating or (only sometimes) just when driving normally. It’s only usually an issue when the lights are off, but very very occasionally when they’re on they will flash off for a second or two in the same situation.
Wiggling the stalk a bit with the lights off seems to trigger the same issue so I think it’s likely a lose or worn connection or wire in the switch unit.
I can easily take the switch unit off and apart and everything (had to replace the clock spring last winter) but wondered if anyone’s had similar issues and if it’s an easy fix, or better off getting a whole new unit?
Thanks in advance!
Thanks in advance!
