Technical '08 Wing mirror
dfk
Just wondered if anyone had changed an electric wing mirror on an x250.
I prised off inside plastic easily breaking it in the process. Undid 4 bolts but can't get electrical wire to pull out.It appears to be going to the center of the door.Must I completely strip inside of door and how do I do this.Undid some screws but still seems to be tied somewhere around the speaker side.
Don't want to force anymore plastics.
Any help appreciated.
Hi
Remove the window switch and speaker you should be able to see the multi plug, just unclip an pull out the wire. When refitting I have had some mirror units with a larger locating peg if this is so just cut it off flush. Good luck.:)
Thanks Fubar.The window switch lifts out but I cant seem to shift the speaker cover does it just pull off.
Thanks.Thses plastics seem to break easy though or else I'm very strong.
Cheers Fubar mirror changed.I won't be breaking that again.
