stevietease
- May 1, 2020
- 16
- 8
Guys,
Ive got a snag starting my 1.9 JTD Punto (2005)
It takes ages to fire and then gives a 'check glow plugs' error.
Ive checked the relay connector to plugs lead with a multimeter and get 1.2ohms on all 4 wires, ive also changed the relay for a new gen one but still get the same problem.
When i turn the key the glow plug lamp on the dash only illuminates for a second and then goes straight out regardless of whether the car is started from cold or warm.
The battery box relay fuse has also been checked and is good also so the relay is getting a feed.
Ive tried spraying all the connectors with elec cleaner and putting back together but no difference.
To me it can only be the wiring to the relay or some type of ECU fault now?
Not sure where to look now so any advice will be greatly received.
Cheers and TIA
Cheers and TIA
