Now I know I could online research this but thought I would ask here as some of you may already have the answer which will get a wider audience here.
So you have an EV vehicle that you want to charge at home.
The basic question is this. How do you, can you select that charging capability.
e.g. plug into a standard 13Amp supply (suitably cabled) and not attempt to draw more that 13Amps (or any other current limit).
Is this charge cable defined (by physical cable wiring) or a vehicle menu setting?
