Yatour problem not working
Bordeaux120
Hello,
in my Fiat Croma I had installed a Yatour, that have been working until its connector got damaged by corrosion.
I bought a new Yatour, Fiat-compatible, completly unplugged the old one and plugged in the new parts - the cable and the device itself.
Thing is, the new one doesn't work.
When I select "cd" on my original radio, it shows the source as "aux". And I can only toggle between "aux" and "fm/am". With the old Yatour, I was able to correctly select "cd" and listen to music from the Yatour.
Moreover, I have a flash usb that, when plugged in, turns on a led. Well, when I plug it into the Yatour, it doesn't turn on the led.
Is my new Yatour faulty or I am missing something?
Please help :cry:
Solved; the Yatour I bought is not compatible with my car; I have not read precisely enough the item description, when I bought it.
I'll buy a Yatour that fits my car - simplest option.
It may be possible just to buy a proper cable, but, according to the manufacturer, the Yatour device itself is different. So with a proper cable it may still not work.
