Hi and thank you for your help.
I bought my son a Bravo 2007 (198) 1.4 T-Jet.
Long story short I bought it with the left-front ABS giving an error.
A mechanic check it out after having done the diagnostics and pointed out front-left.
The cable of the sensor was interrupted and he fixed it. Still it did not pickup any signal from the wheel. The mechanic told my son that someone put in the wrong CV-Joint which does not have the pickup (gear or something) on the shaft.
After doing some reason and a lot of help from people on the Bravo thread, I am starting to doubt the mechanic ... not about the diagnostics but the fix. He told my son we will need a new CV-joint.
Where does the ABS sensor get the signal from? Someone told me the "pickup" is from the ball bearing in the hub.
I will really appreciate if someone can tell me where it picks up from on the wheel? I search Google and everything out there but cannot find a picture or diagram showing me the exact point it pick up from.
Thank you for your help.
Greetings from South Africa.
