FIAT Auto Specialist Team
Old 2 Weeks Ago   #1
katanabandit1 has donated!
Stop start wont calibrate
HI guys, hoping you guys can help. My alfa guilietta 2.0 jtdm had a broken wire on the start stop sensor (gearstick bit). I had it replaced but when it comes to calibrating it on multiscan ecu its say complete and nothing has changed. And still say neutral position sensor. I have had it in at a auto electrician to fully check all the wiring and everything is fine. When plugged into the diagnostics it shows the gears changing etc when you move the stick but it will not set the neutral position. Does anyone have any ideas? The check engine light is on because of this and i have run out of ideas on how to clear the fault.
katanabandit1 is offline Reply With Quote Quote
Old 2 Weeks Ago   #2
Re: Stop start wont calibrate
I saw a post on a different forum with a panda that had same problem
Solution was carry out the change gearbox procedure on scan tool then calibrate neutral position.
This may work for you.
Good luck
Please let us know
jackwhoo is offline Reply With Quote Quote
Old 2 Weeks Ago   #3
I will try anything. Its really doing our heads in.
Old 2 Weeks Ago   #4
Quote Originally Posted by katanabandit1 View Post
You are not the only one
https://www.digital-kaos.co.uk/forum...-no-gear-learn
There is the forum I read-can't believe found it again....
Hope it helps
I'm going to lie down in a darkened room
Jack
Likes varesecrazy, katanabandit1 liked this post
Old 2 Weeks Ago   #5
Thanks i will let the garage know. I phoned the ALFA dealers this morning in Leeds and got the standard answer you need to bring it into us, rather than a quick word with a technition that had probably come across this loads of times to point us in the right direction of have you tried this approach. Bearing in mind we are in lockdown and and my "local ALFA dealer" is 25 miles away. Rather than my old dealer which has closed down ( was ten mins from us). Hence it being in at a local normal garage. But hey ho probably the last alfa we get. Although probably get the same help level from other brands too. Rant over. Lol
Old 2 Weeks Ago   #6
I don't know for sure but think that MES should be able to do the procedure .
MES is a lot more capable than many scan tools
Old 2 Weeks Ago   #7
i have multiscsn ecu on my old pc that i did the original diagnostic on the car with. I had a quick look last night when you mention it. Only thing i could see about it was changing a tct(auto) box. It is a old version though to be honest on my old windows xp laptop so i csnt update thr software.
Likes jackwhoo liked this post
Old 1 Week Ago   #8
Finally got it sorted. Turns out the switch was not calibrated properly with the red tag from the factory so was giving out a incorrect value setting. So auto electrician had to get it to set right giving off 2 amps instead of 2.1 when in neutral. Then put it back on the car and set neutral position on his diagnostics. Back to all working good now. Sport switch etc back working and engine management light off. Even he said he has done loads of these switches but never had one as awkward to setup as this one.
Thanks varesecrazy thanked for this post
Stilo, 3door, 1.8 in Black. Fitted extra's 17"claws, Abarth skirts and Spoiler, Auto headlights, Headlight Washer Jets, Auto wipers, Rear Parking Sensors, Hifi upgrade, CD Multi-changer,Yatour Cd emulator/mp3 player 2 stage heated seats, Cruise Control, Bluetooth ,Stainless Exhaust! Eibach Suspension! Xenon Headlights two tone leather interiorConnect Nav+ Brushed stainless kick plates
(T) Start stop.... then wont start. ruby67 500 6 03-01-2019 23:52
(T) Car will not start then wont stop until its in reverse alves Grande Punto 13 29-12-2013 21:07
(T) Start&Stop in stop-and-go traffic Mondaugen 500 63 17-10-2011 08:07
(T) Start stop - How long does yours stop for? Ransoman Punto Evo 9 17-08-2011 12:52
(T) car cuts out and wont start ! and other car wont start also ! petrol and diesel waggy190 Multipla 7 06-12-2010 17:36
