fiat 500 engine PUNTO
james54
PETERHEAD scotland
Hi looking for some help we changed a fiat 500 2013 1.2 engine we put in a fiat 2015 punto 1.2 engine same engine codes we used fiat 500 2013 starter motor the cars is starting but the starter keeps going for a few seconds will the starter be different do i need a punto 2015 starter
does this mean new starter and thanks for the help
Old starters were permanemtly engaged on the engines ring.gear on the outside of the flywheel (pre.engaged)
Modern ones the driving gear is 'tucked.in' and as the motor spins it ..it also throws it out to line up with the flywheels ring gear
IF it sticks out there.. you will still hear the starter spinning..
As it is being driven by the engines power.. not battery power
Question:
Did you swap flywheels..? there is a chance the profiles are different
But.. spin the starter on its own.. see if it is sticky.. it does happen
Charlie
