Hello all,
I digged the internet to find any Fiat specific OBD2 PIDs, to complete my full LCD instrument cluster. There is very little to no info on the internet about those PIDs, but I found a list of Alfa PIDs, where in that list, it mentioned Fiat. Can it be that those Alfa PIDs are also used in Fiat vehicels, because they are from the same manufacturer?
The list i found (it is a long list):
PID PID_Name Calculation_Formula Result Text BytesInResponse StartFromByte BytesForCalculation
1A80 Reading Identification Code FIAT drawing number 61 0 11
1A80 Reading Identification Code HW number 61 11 11
1A80 Reading Identification Code HW version 61 22 1
1A80 Reading Identification Code SW number 61 23 11
1A80 Reading Identification Code SW version 61 34 2
1A80 Reading Identification Code Homologation number 61 36 6
1A80 Reading Identification Code ISO code 61 42 5
1A80 Reading Identification Code Tester code 61 47 10
1A80 Reading Identification Code Production date 61 57 4
1A91 FIAT drawing number FIAT drawing number 11 0 11
1A92 HW number HW number 11 0 11
1A93 HW version HW version 1 0 1
1A94 SW number SW number 11 0 11
1A95 SW version SW version 2 0 2
1A96 Homologation number Homologation number 6 0 6
1A98 Tester code Tester code 10 0 10
1A99 Production date Production date 4 0 4
2101 Injection control unit X&0b00000001 X=0b00000000 Programmed 1 0 1
2101 Engine startup X&0b00000010 X=0b00000000 Allowed 1 0 1
2101 Universal code X&0b00000101 X=0b00000101 Received 1 0 1
2101 Injection control unit X&0b11111111 X=X Not programmed 1 0 1
2101 Engine startup X&0b11111111 X=X Not allowed 1 0 1
2101 Universal code X&0b00000101 X=0b00000001 Not received 1 0 1
2101 Universal code X&0b11111111 X=X Not enabled 1 0 1
2103 Odometer X*0.1 km 3 0 3
2108 Number of overrevs X*1 1 0 1
2109 Max. eng. speed counter X*10 msec. 2 0 2
210A Maximum engine speed X*40 Rpm 1 0 1
210B Number of rewrites X*1 1 0 1
210C Odometer at last rewrite X*0.1 km 3 0 3
2121 Cyl. 1 fuel correct. (X<0x8000) ? X*0.01 : (X-0x10000)*0.01 mm3/inject2 0 2
2122 Cyl. 2 fuel correct. (X<0x8000) ? X*0.01 : (X-0x10000)*0.01 mm3/inject2 0 2
2123 Cyl. 3 fuel correct. (X<0x8000) ? X*0.01 : (X-0x10000)*0.01 mm3/inject2 0 2
2124 Cyl. 4 fuel correct. (X<0x8000) ? X*0.01 : (X-0x10000)*0.01 mm3/inject2 0 2
2125 Cyl. 5 fuel correct. (X<0x8000) ? X*0.01 : (X-0x10000)*0.01 mm3/inject2 0 2
2130 Engine speed X*0.25 Rpm 2 0 2
2131 Vehicle speed X/128.0 km/h 2 0 2
2132 Cruise lamp X&0b0000000000000001 X=0b0000000000000001 Off 2 0 2
2132 Cruise lamp X&0b0000000000000010 X=0b0000000000000010 On 2 0 2
2132 Cruise lamp X&0xFFFF X=X Flashing 2 0 2
2133 Glow plugs lamp X&0b0000000000000001 X=0b0000000000000001 Off 2 0 2
2133 Glow plugs lamp X&0b0000000000000010 X=0b0000000000000010 On 2 0 2
2133 Glow plugs lamp X&0xFFFF X=X Flashing 2 0 2
2134 Water temperature w. lamp X&0b0000000000000001 X=0b0000000000000001 Off2 0 2
2134 Water temperature w. lamp X&0b0000000000000010 X=0b0000000000000010 On2 0 2
2134 Water temperature w. lamp X&0xFFFF X=X Flashing 2 0 2
2135 Oil pressure w. lamp X&0b0000000000000001 X=0b0000000000000001 Off 2 02
2135 Oil pressure w. lamp X&0b0000000000000010 X=0b0000000000000010 On 2 0 2
2135 Oil pressure w. lamp X&0xFFFF X=X Flashing 2 0 2
2136 Water in fuel filter lamp X&0b0000000000000001 X=0b0000000000000001 Off2 0 2
2136 Water in fuel filter lamp X&0b0000000000000010 X=0b0000000000000010 On2 0 2
2136 Water in fuel filter lamp X&0xFFFF X=X Flashing 2 0 2
2137 Power-latch duration X*1 msec. 2 0 2
2139 Failure lamp X&0b0000000000000001 X=0b0000000000000001 Off 2 0 2
2139 Failure lamp X&0b0000000000000010 X=0b0000000000000010 On 2 0 2
2139 Failure lamp X&0xFFFF X=X Flashing 2 0 2
213D Brake pedal status X&0b00010000 X=0b00010000 Pressed 1 0 1
213D Clutch pedal X&0b00000001 X=0b00000001 Pressed 1 0 1
213D Brake contact 2 X&0b00100000 X=0b00100000 Pressed 1 0 1
213D Accelerator pedal X&0b00000010 X=0b00000010 Accelerator potent. track 11 0 1
213D Brake pedal status X&0b11111111 X=X Released 1 0 1
213D Clutch pedal X&0b11111111 X=X Released 1 0 1
213D Brake contact 2 X&0b11111111 X=X Released 1 0 1
213D Accelerator pedal X&0b11111111 X=X Accelerator potent. track 2 1 0 1
213E Accelerator pedal (X*100)/65535 % 2 0 2
213F AD/C accelerator posit. 1 X*0.1 mV 2 0 2
Problem is that I don't have a way to test this. I am planning to buy all the components only when I think the project is able to be completed.
