murvisteve
- Oct 5, 2020
- 5
- 2
I have a 2005 Fiat Ducato converted by Murvi to a Morello campervan. recently my engine management warning light came on. I carried out a diagnostic check using a Foxwell NT530 and it returned results which pointed to the key.
It was a fault code 04 which translated refers to 'battery voltage to low or intermittent. It was the same for both keys.
I have cleared the fault and the warning light is off, but the fault code keeps returning on subsequent scans.
The keys in question are type A, ie they do not have the remote control function, which is on a separate unit.
Do these keys have batteries? Are they straightforward to replace if needed? as both are the same age, I guess both should be replaced if that is the case.
Any thoughts anyone.
