gavinperkins11
- Sep 30, 2020
- 5
- 1
Hi all, got a 2013 fiat florino 1.3 multijet. Got to start it cold or hot and it just turns over for around 10-15 seconds as if the fuel has run back to the tank. No fault codes, replaced the fuel pressure sensor on the rail, just fitted a new pump with the new pressure reg, when on live data checking the rail pressure its on 0 until the engines cranks to start then it flies up and starts, knock engine off and it drops all pressure almost straight away. Checked the fuel pump in the tank and that's all working like it should. Any advise would be great,
