Old 23-07-2020   #1
Diwiak has donated!
Slovakia
Cheap OBD2 diagnostics?
Iam looking for some cheap diagnostics for home use, currently I want to read all modules on Punto 2 2005 (my old cheap ELM327 works only with engine/ABS),
any suggestions / experience,
what do you think of cheap "DELPHI" diagnostic sockets over aliexpress??... Is that any legal/safe?
Thanks.
Panda Plus(319) 1.2 69k EURO6 S&S Sicilia Orange
Punto(188) 1.2 8V 60k Rosso Vulcano
(RIP Cinq Sporting 1.1 Silver)
(RIP Sei Brush 1.1 Orange/Gray)
Diwiak is offline Reply With Quote Quote
Old 23-07-2020   #2
varesecrazy has donated!
Re: Cheap OBD2 diagnostics?
MultiECUScan
Likes portland_bill liked this post
Old 23-07-2020   #3
Diwiak has donated!
Slovakia
I mean diagnostics modul, not software. Iam already using MES/FES, Torgue, AlfaOBD..
What do you think of cheap "DELPHI" diagnostic sockets over aliexpress??... Is that any legal/safe?
Old 29-07-2020   #4
Turkey
If you already have the MES and adapter cables, all you need is KKL/VagCom interface.
It looks like the only module you can't access is the airbag am I right?
If so, it would be more expensive to go buy one of those Delphi clones rather than buying KKL/VagCom along with adapters if you're only planing to use it on Fiat cars...
Also I just looked up those Delphi's on AliExpress and they seem to ship with a keygen so their software is pirated...
Besa is offline Reply With Quote Quote
Old 30-07-2020   #5
Diwiak has donated!
Slovakia
Thanks. I have cheap ELM327 adaptor with shortened Pin 7, I can access engine+ABS, but nothing else. MES says electric delphi servo can be accessed only by ELM, is KKL/Vagcom any compatible?
Ive been searching a bit about those cheap Delphi interfaces, afaik its 1to1 copy of genuine Delphi interface with "fixed" genuine software, means illegal, you are fine with it anyway until you dont connect to internet and for cars manufactured till some 2015-17, new software (2017+) is much better protected. Delphi is charging approx. 2000 for interface and 600 annualy for updates so nothing special they are fighting it seriously ;-).
Old 30-07-2020   #6
Trader Rating: 1
portland_bill has donated!
If you have MES, you just need a set of the adaptor cables to use with your ELM.
I have a KKL/Vagcom interface, have never managed to get it to work with MES on my Panda, or any of three other Fiats I've tried it on. It does not connect to my Fabia either, using any one of three cheap OBD programs (and that's a VAG vehicle), but the ELM works on it with all three programs.
I have managed to get the KKL to work on a Peugeot 307. (Although I'd prefer not to be anywhere near the Peugeot.)
Likes Diwiak liked this post
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 30-07-2020   #7
My KKL has been fine..
PB and I will have to swap cables..experimentally
as there is still a panda in circulation locally
Old 30-07-2020   #8
Trader Rating: 1
Quote Originally Posted by varesecrazy View Post
Squeak at me whenever it seems convenient, we'll give it a try.
Old 30-07-2020   #9
Pretty sure my 04 panda was a KKL user ..
ELM.. gets a lot of use now.. next generation
Old 30-07-2020   #10
s130 has donated!
I switch to OBDLINK SX interface a few years ago. Was helping Yani (MES developer) with 500X Proxi errors. The 500X was sending data back faster than ELM could handle and overrunning the ELM receive buffer.
We got it going with OBDLINK straight away and then with ELM. With ELM Yani had to switch the ELM into a little used FAST mode for Proxi. Not all ELM devices are capable of being switch to this fast mode and certainly not the Chinese clones.
ALSO NOTE! You should only get your Genuine ELM interface from an MES authorised distributor as these WILL work. Cheaper Ebay/others may work bat are just not worth the hassle.
See:
https://translate.google.com/transla...-achtung-falle
http://forum.multiecuscan.net/viewtopic.php?f=5&t=1493
Likes Diwiak, varesecrazy liked this post
s130 is offline Reply With Quote Quote
Old 30-07-2020   #11
Trader Rating: 1
Quote Originally Posted by s130 View Post
See:
I've seen the OBDlink interface, perhaps you can answer a question. Does this then do away with the need for the adaptor cables, or does it still need them? Thanks.
Old 30-07-2020   #12
s130 has donated!
Quote Originally Posted by portland_bill View Post
No you still need that adapter cables.
Our 2005 Barchetta needs a KKL for the airbag on the OBBDII 16 pin dianostic connector as ELM does not work. Last time I had to reset the squib errors (common problem) I forgot to try the OBDLINK interface. Must try and remember to try this next time.
Thanks portland_bill thanked for this post
Old 30-07-2020   #13
Trader Rating: 1
I shall not bother yet then, as the ELM works fine. Unless I tread on it like I did with my first one, it didn't like that.
Old 30-07-2020   #14
s130 has donated!
No I would not either. If you have a working ELM device and no issues then OBDLINK is not really required.
For new comers to MES/other diag software they see ELM and look for the cheapest interface they can find assuming if it is an ELM device it is OK. Sadly this is so far from the real truth with these cheap clones.
I've not yet seen any issues with OBDLINK interfaces BUT they are also more expensive.
Like I said Yani solved the Proxi issues with known good ELM devices when used with certain later Fiat models so using a known good ELM device is not an issue anybody should be concerned with.
When you purchase OBDLINK you also get their software so the ELM only to OBDLINK + Software price differences may be to some peoples liking.
Old 30-07-2020   #15
Turkey
Quote Originally Posted by Diwiak View Post
So you modified your interface to access the ABS module without any adapters?
If thats the case you should revert back to original as it could be interfering with other modules on that bridged K-Line...
You should be able to connect all modules except Airbag and ABS using unmodified ELM327 and no adapters at all. If you can't, you most likely have a bad ELM327 or an unnecessary termination resistor on the CAN lines (pin 6 and 14).
(G) Stilo Obd2 Chiptuning - Nitro Obd2 nikiforos83 Stilo 2 21-04-2016 16:14
(T) Diagnostics check North West or cheap box? foggymx5 Panda 6 14-02-2014 09:02
(T) OBD2 Diagnostics Tim T Stilo 8 06-05-2006 21:40
