Old 1 Week Ago   #1
Post Starter Motor
Hello all,
I have a fiat grande punto 1.4 16v sporting and my starter motor is dead. Im at university and don't have a jack how hard is it to replace from on top of the engine bay?
Cvllen is offline Reply With Quote Quote
Old 1 Week Ago   #2
Ireland
Re: Starter Motor
I'm not overly familiar with the Punto but I don't think the starter motor can be changed from on top of the engine bay. (I have a 1.4, 16v Bravo, same engine?)
If you don't have a jack, maybe get help to push the car and put 2 wheels up on the highest kerb you can find, this should allow you just about enough room to slide underneath.
Are you sure the starter motor has failed and it's not a problem with the battery, battery connections, battery cables or a poor earth connection?
Iirc, some Punto's have aluminium battery cables/leads and hidden corrosion can occur between the cable and terminal. This is what I'd check out after checking the battery.
You might try reposting this query in the 'Punto Grande' section of this forum- doing so will possibly reach more of those who know your model.
Al.
Thanks jackwhoo thanked for this post
Likes Cvllen, jackwhoo liked this post
F123C is offline Reply With Quote Quote
Old 1 Week Ago   #3
varesecrazy has donated!
Quote Originally Posted by Cvllen View Post
Hello all,
Hi..almost impossible
How do you know it has failed..?
A poor electrical circuit is a more common failure..
Charlie
Old 1 Week Ago   #4
Re: Starter Motor
Do the 'jump lead test' before worrying about the starter..
Failure of the internal structure of the battery to motor : gearbox earth cable is telatively common.
Which variant do you have..?
if its a manual..
Try tow.starting.. the starter may well function.. once the motor has run
Please feel free to update us when you have more info
Charlie
Old 1 Week Ago   #5
Hello all,
I have had a new earth cable as my old one snapped so thatís been replaced last year with a heavy duty cable, the alternator is less than a year old and so is the battery. The car bump starts and drives fine. I bought the car on 120k miles and itís now on 206k and the starter hasnít been changed since Iíve owned it and not sure when if it was replaced before I bought it. Iíll double check all the connections. A close friend of mine whoís t-jet swapping a panda said itís most likely the starter motor as it happened to one of his old cars. Thank you all for the help so far
Old 1 Week Ago   #6
Re: Starter Motor
Hello all,
Is the battery ok? Even though only year old ,
Fully charged?
Has car been unused for weeks due to lock down?
Batteries go flat in only a few weeks due to very small loads on battery even when ignition key not in car.
Likes F123C liked this post
jackwhoo is offline Reply With Quote Quote
Old 1 Week Ago   #7
Re: Starter Motor
Great work keeping a high miler going
You are doing your bit
Likes Cvllen, F123C, varesecrazy liked this post
(G) help with starter motor caddy Scudo 2 26-01-2015 18:43
(T) Punto Mk2 will not starter - starter motor issue? macbrew Punto (Mk2/2b) 9 31-03-2014 20:40
(T) X 1/9 starter motor lancepbul X1/9 0 14-12-2011 05:09
(T) Starter motor shaun X1/9 6 18-04-2009 16:08
(G) Starter Motor brouser Ducato 0 21-07-2006 08:16
