Hello- this is my first post and first visit to the site. I found the site as I'm at a crossroads on my next move and looking for some advice. Hopefully I'll become a frequent visitor after this repair!
Here's the situation (sorry for the long post)-
I've got a 1977 Campagnola that will die when driving. It has a 2L gas engine. It will idle all day but within 15 mins of driving, it'll start to lose power, start to miss, and eventually die. Then it won't restart again for 2+ hours. I'm thinking I have too much heat on the fuel system and don't have a return fuel line, leading to vapor lock. I'm running 4.5 psi in the fuel system and haven't noticed any leaks. About a year ago I had rust in my fuel lines so I cleaned the system, including stripping and sealing the inside of the fuel tank, and replaced the inline fuel filter.
I'm curious before I start replacing parts if anyone has any other suggestions?
Apparently some of these vehicles (later, 79+ from what I can tell), had the fuel return line right off the carb. Mine does not have that piece on the carb to connect a second line and if I can find the right carb with the piece, it would be several hundred dollars for something I'm not sure will fix the problem. Perhaps I could T off the fuel line before the carb and add a return line that way? This is all just guesswork at this point.. Thanks in advance..
