Hi, Fama,
Thanks for your reply.
I can fully understand the difficulty/cost in obtaining parts from abroad. (I worked as a volunteer in Djibouti, N.E Africa for a while in the 1980's setting up and running a training workshop for refugees/locals) - so am familiar with extreme poverty and the severe limitations/restrictions it imposes on people. Here In Ireland, we have to import all our vehicle parts, supplies, tools etc. But although most here, who work on older vehicles, would be the poorer in our society, at least we can in many cases manage to buy such exotic costly items such as adjustable suspension set-ups on the second-hand market when the affluent 1st owners have finished with them.
My reason for mentioning the 'adjustable suspension struts' was to give you a term to search for on the internet, so that you could look at an image of these and perhaps give you some idea on how you could incorporate some adjustability into your existing front struts lower spring mounting should you decide to alter their position by cutting and rewelding them. One thought I had was to use heavy threaded tube slipped over the strut body - one possible source of such threaded tube would be from adjustable builder's scaffolding or props - take a look at the adjustable thread on
www.acrow.co.nz/props/acrow-props (for reference, these 'Acrow props' have a 60.3mm outside diameter rolled thread)
But on further thought, this might not be such a good idea as it might result in spring binding if they have already sagged a bit.
RE :- the steering column seeming a bit 'flimsy'. Many such items are designed to bend/fail in the event of a severe collision in order to reduce injuries to the driver. These items will have been exhaustively tested by the manufacturer and shouldn't fail in normal use providing any universal joints/rubber couplings are checked/maintained/replaced if worn and that any clamps are kept tight. I'd be guided by local drivers and mechanics of your type of vehicle as to whether or not this steering column/shaft is reliable under local road and operating conditions. (In Djibouti e.g. away from the main roads, most roads were just tracks often rock-strewn and corrugated by heavy traffic - these conditions were very hard on vehicles incl. normally sturdy 4WD jeeps would be shaken apart and required a lot of additional checks/maintenance).
I'd stick with the original steering column unless locals tell me otherwise. You might check that this item fitted to your Italian import vehicle is the same as other Ducatos used locally - sometimes manufacturer's fit different parts to some areas of a vehicle to suit local conditions e.g. oil-bath air cleaner for dusty markets vs paper element for everywhere else.
I don't know a lot about EGR's. I've heard that in many cases they can be removed, stripped and cleaned using a powerful solvent/cleaner (i.e. something that can dissolve carbon). Afaik, the function of the EGR system is to improve exhaust emissions. Some say it's blanking off/removal will boost power a little. But the process of injecting some exhaust back into the cylinder has the effect of lowering peak cylinder temperatures also. This has a potentially protective effect on the engine. Given that your vehicle is a bit older, As long as the EGR is not choked-up/stuck open, I'd leave it in place to do it's job. Again be guided by local owners/mechanics but be careful of advice from others who don't understand how the part works or is supposed to work or those who just 'follow the herd' doing something because everyone else does it (without knowing why or the possible consequences).
Re:- Thermostat removal - as recommended by all local mechanics...…
The main function of the thermostat is to allow the engine to warm up quicker and allow the heating/demister to work sooner. In your hot climate, the engine may need little warming up and the heater/demister might not be needed. (I do know from experience working in the Middle East, that it can get very cold in deserts at night...). A quick warm up of the engine to normal operating temperature can save a little on fuel and may also reduce engine wear.
As long as the thermostat is working normally I'd leave it in place but I would check that there are no leaks/impending leaks anywhere in the cooling system, that the water pump is in good condition (no signs of leakage and the drive belt is in good condition/correctly tensioned (many modern engines use the engine timing belt to also drive the water pump, - I'm not sure what's on the Ducato). If plain water is used instead of an anti-freeze mixture, this will boil at a lower temperature and also allow corrosion/scale to build up in the coolant system resulting in reduced flow and therefore reduced cooling, both of which can result in overheating.
Most important maintenance item in the cooling system is probably the radiator. It must be kept leak free, clean inside (i.e. good flow) and clean on the OUTSIDE i.e. free of dust/sand/mud/leaves (shine a light/torch through the fins to check) and nothing in the way of good airflow through it's cooling fins. Some fit spot/driving lamps in front of the radiator grill, some mount airhorns etc, some mount the front registration/licence plate in front of the rad. grill, in deserts, some hang water bags/containers in front, some mount placards/flags etc in front during elections/celebrations etc. all big no-no's if you want your vehicle to keep it's cool. Also, running the air conditioner, if fitted, will tend to push up engine temp.
I'd leave the thermostat in place if it's working normally, just keep an eye on any water temperature gauge/warning light whenever driving conditions are extremely hot/ climbing hills/ stuck in traffic etc. Never be tempted to drive if the cooling system is overheating - stop as soon as it's safe, allow to cool down naturally, don't top up the system until cooled down - adding cool water to an overheated system can do major damage.
The cooling system on your Ducato is a sealed system. This is designed to build up pressure in use. To do this, the system must be free of leaks and the pressure cap fitted must be in good condition. Running the cooling system under pressure raises the temp. at which the coolant boils and turns to steam. The use of anti-freeze raises the boiling point compared to plain water.
It's also possible to use what is referred to as 'waterless coolant' this prevents corrosion/rust in the system, only turns to steam at 180 degrees C. compared to 100* C. for water and maybe 110*C. for normal water/anti-freeze mixture. For info on waterless coolant, plus some additional info on cooling systems see
www.evanscoolants.co.uk
And No!, I'm not suggesting you try to get hold of or use this stuff - it's very, very, pricey, even over here - it also requires the use of a pricey preparation fluid, no leaks to be present and can't be topped up with anything else other the same coolant, certainly not water, otherwise it's beneficial effects are lost. I've never used this stuff!
So, to summarize, my recommendations would be to :-
Leave the steering column standard unless it has given trouble on local vehicles of the same type.
Leave the EGR system in place if it's working normally. Might be worth investigating if it can be cleaned out.
Thermostat - Leave in place unless you're having problems, but worth checking over the cooling system as described above, especially keeping the outside of the radiator fins clean/clear. If your Ducato was built for the Italian market, it's cooling system would have been designed to cope comfortably with temperature up to at least the low +40*C (the max? temp in Italy in summer) so hopefully will be fine for use in your country.
Regards,
Al.
