im Axle Specialists
Old 26-10-2019   #1
varesecrazy has donated!
Cabin fumes. 1.3 mj punto
After a long drive we are now 100% sure that engine fumes are entering the cabin.. on our tidier 07 mj
Got it up on a tyre and exhaust centres ramps.. other than plenty of rust.. all appeared sound.
The car is lousy on fuel 54 vs 68
History.. owned for 10 months.. always had an occasional hint of gasses: fumes
No obvious issues found.
Oil level hasnt moved..and motor looks dry outside.
Oil not changed ( due this week)
What is the EGR : Recirc system like on these mj's ?
Last run was 60 mph for 2 hours..
our clothes smell of the fumes.. NOT HEALTHY..!!
Air flter is good.
Fuel filter.. unknown..
Glowplugs replaced on purchase.. runs soundly.. just not 'right'
Old 29-10-2019   #2
Re: Cabin fumes. 1.3 mj punto
Would a choked EGR do this?
Appears far worse once up to temp..
Old 30-10-2019   #3
chris3234 has donated!
If it's sticking open I'd imagine I'd guess there would be a lot of build up of carbon and crap in the inlet
Perhaps remove the map sensor and see if there's a lot of black carbon gunk on it
chris3234 is offline Reply With Quote Quote
Old 13-11-2019   #4
Updates due:
Injector seals: appears dry in there.. when Im ready to drive it again.. I might put some water in the wells and check for bubbling-froth.
MAP Sensor: plug is not 'locked' so has obviously been disturbed.
Info on cleaning and testing would be most welcome
MES Testing.
Both of my mj's sound pretty similar when you cycle the EGR solenoid
Are there other helpful figures I can compare from the comfort of front seats?
EGR solenoid. Shuttles on demand with MES..and the same muffled tone on both cars.
The EGR body just appears as a 'finned cup' 3 x securing screws and a connector on the end.
No obvious water connections.. can I just uncouple the finned body?
Pics in next line.
Old 13-11-2019   #5
Pics of injectors. MAP sensor. EGR Valve
ID:	204439   Click image for larger version
Old 28-11-2019   #6
Ok..
After a cooked battery
Car is now back to running reliably.. but still got fumes
I did the injector seal test.. filled the wells with water.. ran engine.. no leakage..or bubbles.
(I thought it was fine as area looked ok.. see previous pics.)
This weeks running around has shown me that sitting at busy juction obviously builds fumes under bonnet
So by the time you pull away and get to 10mph its pretty strong again
So.. what next?
Talk of screen wash stinking.. unlikely.. as I never spray the stuff..
Might just dump it though..
EGR.. sounds VERY time consuming
Boost hoses..? A bit of a faff.
One idea..
On all my old FIRE petrols ( and older..)
There was a recirc hose coupled with the air filter..
Not seen anything obvious on the mj..
Is there a rubber recirc hose anywhere that could be open to atmosphere?
Old 04-12-2019   #7
Ok..
I believe the problem has been found
Parked the 2 mj's side by side..
Took pics of rear of engine.. looking for differences
1: shiny
1: sooty
ID:	204851   Click image for larger version
Old 04-12-2019   #8
Contemplating a 'gungum - exhaust bandage' type of patch to see if that made the difference..
I studied the pics more closely..
The retaining clamp is at a jaunty angle
Just hope I can get it all back together properly.. looks like its been there a while !!
Old 04-12-2019   #9
The good ..the bad..
and the fuglee
ID:	204853   Click image for larger version
Old 06-12-2019   #10
Complex issue..
I will start a new thread
(T) fumes in the cabin gordinir8 500 (Classic) 15 22-05-2017 19:06
(T) Cabin fumes TempraTDSX Croma 19 20-08-2013 13:37
(T) Fumes in cabin when heaters on.... nottscounty Stilo 3 13-04-2011 23:17
(G) Smell of fumes in cabin Steed 500 7 09-02-2010 12:00
(G) fumes in cabin diggerman Punto (Mk2/2b) 7 26-11-2009 19:53
